    colb replied to the thread Door hinge loose.
    Its the door check strap, sounds like a worn pin in it clicking diagram here item No 2 and the pin is 4...
  • N
    Thank you. Oh man... I'm already scared about fixing my non-reclining seat and now this... Next week will be quite stressful.
    colb replied to the thread Window suddenly stopped going down.
    https://www.realoem.com/bmw/en/showparts?id=CM12-EUR-12-1999-Z3-BMW-Z3_19&diagId=51_2351 Door Parts
    Inside door trim panel here https://www.realoem.com/bmw/en/showparts?id=CM12-EUR-12-1999-Z3-BMW-Z3_19&diagId=51_2343 Once off you will...
  • N
    Nuieve replied to the thread Seat doesn't recline.
    That's what I am worried about, that things will glitch. I did buy the B800 or whatever its called decoder because my airbag light is...
  • N
    Nuieve replied to the thread Door hinge loose.
    Here’s a video: https://streamable.com/s2mfhw
  • N
    "Door card" is a plastic outer trim with leather? Or do you mean complete door disassembly? Sorry about the stupid question, a...
    colb replied to the thread Seat doesn't recline.
    Just be aware that the airbag wiring under the seat will have to be disconnected so you can lift the seat out of the car. Once...
    Since it can still move up and down you need to get the door card off and inspect the glass runners and lift mechanism to see if its...
  • Duncodin
    Duncodin replied to the thread Door hinge loose.
    Can't see the top hinge in the picture. Can you get a better picture of the top hinge? If you're concerned about that thing in the...
  • N
    I just bought this car a few days ago and on the way home I rolled the windows up and down a few times without a problem. I did...
  • N
    My door is making crunching noises when opening. I can see the top hinge is wobbly and not tight. Anything I can do myself or is this a...
  • V
    Vanne replied to the thread 1 day insurance for grandson.
    The car is insured under you right? Cant you just let him borrow the car? Maybe it’s different from Oz? Unless your sending him to a...
  • Althulas
    Althulas replied to the thread Looking for 51-43-8-407-174.
    There appears to a few printing services in Rhode Island https://printathing.com/3d-printing/providence-ri/ Maybe they can scan your...
  • Pingu
    "Crashing" is usually down to worn out bushes. I'd get underneath with a long lever bar and start trying to move stuff that shouldn't...
