Z3 2.8 roadster
:welcome: to the Forum from West Cumbria, England.
Jan 19, 2026
ExMX5owner
Our Wheels of Yesteryear.
My Mustang, 1979 , fitted with a 351 Windsor as opposed to the standard 302. sitting behind my 81 Carolla, also modded to 2 liter DOHC...
Jan 19, 2026
Tomk
Rear bush questions
Thanks for the reply Lee.
Jan 19, 2026
Tomk
Rear bush questions
Was thinking possibly along those lines 👍
Jan 19, 2026
ExMX5owner
I found some older pictures. My 1100 Katana, very few of these were ever made, with wire wheels , smooth bore carbs and not CV's , big...
Jan 19, 2026
jimcwestie
I have bought a new radiator and fan as part of my preventative maintenance for the spring.
Jan 19, 2026
D
David Sims
left a message on
spurs fan in a coupe
's profile.
Hi i'm, in need of a replacement instrument cluster for a Z3 2.2 2001 as mine has the dreaded EEP_2 fault. Ideally with less than 95000...
Jan 19, 2026
S
Sajk
Still dealing with a clunk
Thank you for all the suggestions. The strange thing is that it improves with some heat in the drive line. If that gives anyone a hint...
Jan 19, 2026
Tmdlkwd
New Z3 Owner in SoCal
Jan 19, 2026
Pond
Rebody
Rebody Dashboard
Hopefully this may help... The vertical piece supports the dash in the area with the arrows (yes I DID manage to edit it!!). In my...
Jan 19, 2026
D
David Sims
left a message on
's profile.
Hi Andy i'm, in need of a replacement instrument cluster for a Z3 2.2 2001 as mine has the dreaded EEP_2 fault. Ideally with less than...
Jan 19, 2026
Eureka
Z3 2.8 roadster
Introduce Yourself!
Hello Purchase Z3 2.8 roadster Reg 1999 built Dec 1998 alpine white. It had sone modifications, Have change the interior. Hood, Door...
Jan 19, 2026
Pond
Z3 foglight switches
That is exactly the reason for the rears being on a momentary switch; so they don't come back on when the ignition is switched on.
Jan 19, 2026
AntStark
Rear bush questions
@Tomk ^ that is your best option by far. Bring biscuits, drink tea.. drive home happy. No brainer.
Jan 19, 2026
Lee
When the play starts to get excessive it starts to whine. BMW released a technical bulletin once about a particular type of grease...
Jan 19, 2026
