Still dealing with a clunk
I’ve found that causes a whine power on/off. The main issue is wear in the sun and planet gears. The pin wears as do the bushings in the...
Jan 19, 2026
Lee
Most common clunks from the Z3 6cyls are from the diff, they start to loose the pre load in the pinion, very slight clunk as the back...
Jan 19, 2026
A
AlexGSi2000
Gearbox Swap - Getrag to ZF
Cheers Andy, yes mine is the sport with the Diff.
Jan 19, 2026
Lee
Remanufactured engine identification
Look on the back of the engine above the gearbox, you'll likely need a small mirror, theres a big barcode with a load of numbers below it.
Jan 19, 2026
Lee
Rear bush questions
Pro flex are ok, depends which hardness you go with. Most common size rear roll bar is 15mm, best double check with a Vernier. In...
Jan 19, 2026
The prop should be okay. Unless you have a Sport with the LSD, the 2.2 168 diff is 8mm shorter. You should be okay but you might have to...
Jan 19, 2026
shera25
Rear bush questions
I’m no expert, but from what I’ve seen Pro-flex seem to be a bit mixed, some people are happy, some not so much. The ARB sizes do vary...
Jan 19, 2026
Rebody
Rebody Dashboard
@Pond I must confess I don't know what 'angled return piece' you mean. My car doesn't have aircon so maybe there's a difference? Would...
Jan 19, 2026
A
AlexGSi2000
Z3 foglight switches
All the ones I have seen its only the fronts that latch. Back when I was about 9 years old, my dad was fortunate enough to have a new...
Jan 19, 2026
Mine was produced in August 1999 and both switches latch - first photo is before they are engaged and the second is after. According...
Jan 19, 2026
Delk
Rear bush questions
I managed to get a rear subframe and trailing arm at a good price. I rebuilt these as time permitted including new wheel bearings and...
Jan 19, 2026
A
AlexGSi2000
Morning, I'm currently looking at beginning to accumulate parts to swap over the Getrag 240 to ZF 320 on my 2002 Z3. The reason for the...
Jan 19, 2026
Grumps
Rear bush questions
Definitely a question for our bush expert @Lee . He frequently changes bushes for peeps on here.
Jan 19, 2026
Tmdlkwd
Wheel BMW LOGO center inserts or overlays
Yes…going that route now..thank you…on EBay now
Jan 19, 2026
Tomk
Rear bush questions
I have some question relating to the rear bushes on a 2.8 z3. Mine are obviously knackered! So time to replace 😬 as the back end is all...
Jan 18, 2026
