That's what I mean I was assuming you were running cable with the 2.8. Are you not a fan of drive by wire?
Not a fan personally. Like the feel of a cable also no delay.That's what I mean I was assuming you were running cable with the 2.8. Are you not a fan of drive by wire?
The 3.0 is flybywire standard. I'm going to see if I can run it with a larger throttle body and cable.
... Plenty of scope for a little more power...
I've looked at this for mine but the blurb states that you lose low down torque, how would you get that back if fitted?
I’m no expert either mate. Just like playingI'm a mechanical and engineering genius, as you can see @Lee![]()
0-18 years of age = circa £250k mate, just think of the fleet you could've hadI’m no expert either mate. Just like playing
You lot are such a bad influence. I’ve got a little one due in a months time so it’s becoming tough to seek financial sign off![]()
And you've done it 3 times0-18 years of age = circa £250k mate, just think of the fleet you could've had![]()
I hear you!!!!! Everything I buy for the ///M is either reduced, a bargain or just a few quid....it’s becoming tough to seek financial sign off![]()
Granted! Please proceed!I’m no expert either mate. Just like playing
I’m pretty certain the words ‘reduced, bargain, just a few quid’ do not go in the same sentence as ‘///M’, everI hear you!!!!! Everything I buy for the ///M is either reduced, a bargain or just a few quid....![]()
Looks like it’s totally bolt and takes a 2.8 to 275bhp and the 3.0 to 330bhp...
Are you going to keep the lower ratio diff on with the 3.0? Should be pretty lively...The 3.0 is flybywire standard. I'm going to see if I can run it with a larger throttle body and cable.
They do when you're telling your other half what you've just boughtI’m pretty certain the words ‘reduced, bargain, just a few quid’ do not go in the same sentence as ‘///M’, ever![]()
