Rear coilovers too high on lowest setting
John_B
Derbyshire, UK
Z3 2.8 pre-facelift (Izzy)
Afternoon all,
I have just finished fitting coilovers, replacing the lowering springs I fitted last year which resulted in the front axle remaining OEM height, and the rear axle looking like I was carrying breeze blocks (top picture).
With the coilovers the front axle has remained the same height more or less, but I'm not worried about that. There is still plenty of adjustment left to get the front dialled in.
But the rear axle is really concerning me. With the adjustment on its lowest setting it is way too high. I could remove the adjuster and just run the spring and spring pads, but this seems to defeat the whole point of fitting coilovers, on the rear axle at least anyway.
I've reached out to the vendor to see if maybe I have been given the wrong springs, but thought it would be worth asking here too in case I have missed something really stupid (it's my first time fitting coilovers).
Thanks in advance
Duncodin
Pontrhydyrun - in Crow Valley
M44 FrankenZed
I looked a 'ProSport' coilovers and spoke ProSport because I couldn't find anything for Z3 on their site. He explained to me that the Z3 front is the same as other E36 but the rear is same as E30. So standard E36 Rears won't work. The ones to order would be for the E36Compact which also has the same E30 Rear as Z3. But he went on to explain that the rear end of E36 Compact is way heavier than the Z3's so although the rear springs would physically fit they wouldn't lower much.. . He said.
Reactions: John_B
John_B
Derbyshire, UK
Thanks! that would certainly explain what I am seeing! The site I bought them from said they were compatible with the Z3. Hopefully they'll get back to me soon and we can figure something out
Duncodin
M44 FrankenZed
I did buy the ProSport E36 Compact. I'm not looking for lowering. Not much anyway. I'd be happy to fit the rears without the adjuster seats but I can't see that working because the coil that sits in the adjuster seat is much bigger than the original rubber seat so would just slop about.
But I haven't fitted anything yet. Not for the want of trying. I just can't budge the old strut bolts. Rusted totally solid. Try again tomorrow with some heat.
John_B
Derbyshire, UK
I was in the same boat last year. I have two words for you:
Impact. Wrench. 😎
i got a £60 one from Amazon and it's been great. Doesn't get a ton of use, but it's never let me down when I've called on its assistance!
Duncodin
M44 FrankenZed
Impact. Wrench. 😎
Got one. It's supposed to be 550nm. Ordered a decent 18mm six sided socket which came today. Was out there just now with it hammering away. No budge.
Did you try tightening before loosening?
Duncodin
M44 FrankenZed
Yeah. Tight loose, tight loose, repeat.
In hindsight though I didn't press the max button. But that just increases the impacts per minute.
Having a drink now so don't make me go out and play with power tools :)
That could be where you went wrong. Always loosen on Max. power.
IainP
That's a strange looking set, not seen ones that came with new rubber mounts before.
Removing the locking collar will gain you 10mm, fitting the standard rubber top pad another 5 by the look of that pic. You can replace the lower pad with thinner rubber too.
As Duncodin said though, the spring rate is usually higher than a Z3 needs.
Reactions: John_B
John_B
Derbyshire, UK
The pads are floflex ones I had fitted previously. Good idea about removing the locking collar, I hadn't thought of that!
If you are really stuck you're not too far from me, come down I have a nugga that will flip the car over. ;)
Dino D
Kent
2.8 Manual
Had that issue with BC coilovers there for the Z3.
Solved by removing the collars and running the spring pads only.
They came with 6kg springs that were bottoming out badly not helped by the long adjusters threads on the collar.
Changed them for 8 kg and no collar, just the pads and it’s great (can still bottom out but not harshly or as often as before).
I want raise the car now a bit and of course now can’t find the spring adjuster collars(!) may have given them away, but in any case will just use spring pads.
I can’t remember the ratio exactly but I think it’s something like a 10mm spring pad will actually raise it by 14mm because of the geometry (that number is probably wrong but the point was it will raise / lower more than the spring pad thickness)
Hope that helps.
Reactions: John_B
Duncodin
M44 FrankenZed
Afternoon all,
Thanks in advance
I finally got round to fitting my rear springs. I fitted mine with the adjusters at the top. No room at the bottom to get the adjuster wrench on.
At the lowest adjustment the bottom of the rear jacking point is 6 inches off the ground.
I thought about fitting them without the adjusters but the size of the coil is much bigger than the rubber seat/pad meaning the spring could slip about on the pad. I didn't like the sound of that.
Reactions: John_B
John_B
Derbyshire, UK
My circumstances have changed somewhat drastically 😂 - I am buying a 2.8! It was going to be for an engine swap, but in the cold light of day and considering the would-be donor car, I am 90% sure I am chickening out and deferring my soiree into engine swapping for a later date 🤭
Now I need to decide whether I sort the ride height out on this car and sell it with the coilovers, or put the previous set up back on 🤔
Duncodin
M44 FrankenZed
Do you mean that the 2.8 'donor' is now going be restored and kept and the 1.9 is being moved on? I don't know the condition of the 2.8 but if it's fixable then that would be my prefered option.
My coilovers were pretty cheap. If I was selling my car I couldn't be bothered to take them back out. I'd just adjust the front up to match the back and sell it as is.
John_B
Derbyshire, UK
Exactly. From pictures and chatting to the seller I don't think it will need much in the way of restoration, it looks pretty solid.
My thoughts too :) It rides so much nicer on the coilovers too, even with them set to Monster Truck mode 🤭
Reactions: Duncodin
