OK, neither Gaz nor myself use Photobucket so we can't test this to see if it works, so if you want to give it a go, let us know how you get on.
Photobucket fix found on another Forum, I've tried it on this Forum and it works
It is worth noting that this could be a temporary fix as code often gets re-written.
I just found a fix for those pesky Photobucket ERROR images that have xxxxxxed up half the posts from a while back!
If you go to "Edit Post", then simply add, ~original after the jpg bit, it brings the pics back to life!!
*********jpg~original[/img]
There is also a fix if you are using Chrome as your browser
https://chrome.google.com/webstore/sear ... 0fix?hl=en
I clicked the top one.
Taken from the link -
This extension should make photobucket embeds work for all accounts across all websites.
It does this by looking at image embeds and changing the referer.
# NOTE: You may need to clear your browser cache (at least for images) before you will be able to see some images (if you already tried to view them before installing this)
Mike
Mike
Grrrrrrrr!
