Mike’s Z3 - Retro Aircon + Cruise etc Project
MickyG
These are drain tubes are they not?View attachment 352265
This is a very useful community: I’m having fun, hoping to show others how something might be done, and learning a lot from those who share my interest.
Following your comment Synclare I had a sneaky peak at the location for the two tubes you pointed out were drains in my car.
As anticipated there is a patch of body seal applied to the tunnel, which gave me hope there would be press out panels beneath.
And so it proved to be
The two drain grommets will now be easy to transfer over to my car.
So my thanks again for your insight.
Anecdotally one of my major concerns about fitting the whole system is locating the HVAC unit back into place, whilst making sure the two drains from it fit into these two rubber grommets: if you look very carefully at one of the earlier photos comparing the two types of unit you can see the two drains upper most. When installed they face down, (obviously!), and are at the front of the HVAC where it’s almost impossible to see, and even less accessible, all whilst trying to fit it in a very confined space 😮
However killing myth with facts, it was installed in the factory, so it can be done - I just have to work out how 🤨🥴😉🙂
MickyG
You get those with or without a/c condensate; it's a Z3! :D
The donor car I’m stripping the Aircon out of certainly has very soggy carpets!
Which leads me onto an other question:
I have come across a switch in the facelift that looks like a de-mist icon in the rear of the car.
Given that it is a roadster, with a plastic rear screen what would it be for?
Could it be that this car had a hard top, which had a glass rear screen with a built in de-mister?
Is that a thing?
Presumably when fitting the hard top there would be plug-in for the heated rear screen?
Pingu
Is that a thing?
Possibly. The heated rear screen gets its power supplied through the LHS mounting pin. It's a very neat and clever idea, as it means you don't have any wires to connect / remove when changing the hard top.
If you are lucky, they left the fitting kit attached to the car. If they did, and you don't want it, you can sell it, as it's worth quite a lot of pennies.
MuttyMax
Woking, Surrey
1.9 M44 and 2.8
Cruise Control
Choosing the easy one first, I followed an earlier guide on this forum to order just 3 plug and play components to achieve a factory cruise control system.
Cruise Control Column Stalk
Cruise Control module
Clutch Switch
M52TU engined cars are “Drive-by-wire”, making this retrofit very straight forward, along with the fact that all Z3s left the factory pre-wired for Cruise Control.
It is therefore very easy to simply add the column switch by sliding it into the existing mounting slot on the column, and plug it into the existing loom along with the plug in control module. Finally plug in the clutch switch and mount, and that’s it.
I have a standard factory cruise control 😊
(It took only 45 minutes to install once the parts were obtained).
Not all of them (M52TU) ... Ha
MickyG
Sorry, I don’t understand your comment?
My Z3 has an M52B28TU and I have fitted 3 factory components and now have a factory spec cruise control.
All M52 TU engines and M54 can be retro fitted in this way in less than an hour.
I believe it is possible to buy a kit for the earlier M52 engines, but know very little about it, other than it is more complex.
MickyG
Ooooh that’s an interesting prospect😋
Thank you for the heads up.
Next question: what does it look like?
Did the facelift come with the heated rear screen switch as standard, even when no hard top was supplied?
Duncodin
Pontrhydyrun - in Crow Valley
M44 FrankenZed
Is that a thing?
The demist switch at the back of the centre console is for heated rear screen on HardTop. Your donor likely had a hardtop at some time in its.life.
Have a good look to see if the hardtop mounting brackets are still there. They're worth a fortune. Seriously. They're like hens teeth and worth more than you paid for your aircon project.
Duncodin
M44 FrankenZed
This may or may not be relevant to your issue, but the vent pipes are not totally attached to the dash. These two pieces fell out of mine whilst I was removing the dash
The triangle vent on the right you will recognise as the vent on top of the dash: whilst this may primarily direct an airflow on to the side screens, would dome of the air flow not impact your wife’s side of the windscreen?
Below is a view of the underside of the dash showing where the vent tube should be located
And with it in placeView attachment 352275
Looking at the main vent tube it also has a dimple pus on connection, so I think your wife’s problem could well be a simple failure of that connection. As I’ve seen they do fall apart.
Yes. Now that I think about it. The main demist duct is molded into the bottom of the dasbboard. But those little pipes at either end go to the side window demist vent and those little pipes just push onto the ends of the main demist channel. They do come loose easily when fiddling about under the dash or if the top side vent panel come loose. If it's loose it would likely allow air to escape and cause exactly that problem.
Andyboy
SHEFFIELD
I considered fitting AC to my E36 Compact which is the same thing. I thought better of it. 😂
A Bentley manual with wiring diagrams is essential tbh. I'd fit the hard parts, get the dash back in so you have a basic heater as before and gradually wire it up. Fit a new condenser and replace all the O rings as well.
MickyG
Sadly, I suspect
……this means I don’t have a hard top kit still
But does this side suggest it may have had one?
I’ve never seen one so don’t really know what they look like except Google/Ebay photos don’t look like this apart from the rubber cover with a star shaped hole?
Anyone?
Pingu
Sadly, I suspect
But does this side suggest it may have had one?View attachment 352287
Anyone?
Parts aren't there, unfortunately.
Just for info, the hardtop kit was an optional extra.
Facelift switches are different, but do the same thing (obviously =)) ). The facelift switch was next to the air-con switch, and was a lighter duty switch with a relay.
Pond
Spaldingski, Lincs
3 litre Z3 pretending to be Italian exotica. Two previous E89 Z4s.
I’m not as enthusiastic about taking the dash apart so she may well have to live with it for now!
Wise move. Removing dashboards is not something to do just to pass the time IMO.
MickyG
Ha ha - removing it is the easy bit…….. putting it back together is where it gets more difficult!😲
MickyG
So…….. the Aircon installation begins.
First the easy bit:
The two drains, removed from the donor and pressed into the transmission tunnel holes (after cleaning the body seal off around the holes to ensure a good surface fit).
Now we get on to the bit that I expect to be THE most difficult part: installing the HVAC unit to mate up with the dashboard vents and drain plugs all whilst passing the blower through the bulkhead hole, and lining up the two heater pipes to pass through their own bulkhead hole and grommet.
EDIT:
After struggling for 3-4 hours, trying differing sequencing I eventually found a simple way, that were I to do it again would take less than an hour!
Completely re-assemble the HVAC unit (the fan cowl and enclosing flaps had dislodged during removal and I wrongly assumed it would be easier to re-assemble it with them off - how wrong I was!
Remove the rubber grommet from the water heater pipes and Insert it into the firewall. Lubricate it to make it easier to pass the heater pipes though it while installing the HVAC.
Check there are no electrical wires or drain pipes causing an obstruction.
Then in a J-motion the HVAC blower will pass through the firewall quite simply! If only I knew that when I started!
This is where I’m at this afternoon
The HVAC is securely mounted
And the blower and its case fully assembled.
Provided the dashboard goes in AND fully mates with the HVAC’s vents (🤞) the windscreen cover and wipers can be re-fitted and finished outside the cabin.
There are three remaining hurdles that concern me:
The aforementioned dash / vent interface alignment - access to make the vents fit inside the HVAC is virtually zero
Fitting the Aircon pipes that pass through the firewall grommet - access is very difficult.
Pushing the water heater pipes on to the limited stubby pipes protruding through the firewall
Pond
Spaldingski, Lincs
Two words spring to mind when I look at those photos.......SOD THAT!
I re-built a Z3 into something else (and I'm a qualified a/c engineer), but that looks far too much of a PITA for me. The irony is that I have disconnected my perfectly good a/c system aswell! :D
Jam03
Surrey
2.2i
The facelift cars definitely didn’t have the demister switch fitted as standard. My facelift car definitely didn’t, but has a hard top fitting kit fitted, but no demister switch and no hard top when bought it. It’s quite common for people to sell the hard top separately as it’s now worth almost as much as a whole car depending on the condition of the car.
MickyG
However did I find time to go to work…….!!
Although retired I still seem to be limited to the time I can play with my cars. We’ve just had several days away down to Amersham to help move our daughter’s family into their new home.
Never seen so many boxes…….!
Back home and worn out!!
And now it’s turned so cold………
But progress was never easily won: so I’ve had a couple of hours this afternoon and I have my HVAC fully integrated with my dash, water pipe’s connected, and the the Aircon pipes through the firewall connected to the HVAC matrix and the engine bay piping. The dash is in, and secure.
It was all much easier than I expected.
And the cherry on the cake……….. the wiring works (in so far as I can test it): the Aircon button lights up and starts the blower fan, whilst the re-circulation button closes the blower end flaps.
This is a big milestone, with the difficult mechanical installation completed. Obviously there is still a lot of time to go into re-installing the dash and centre console. Also I have to install the receiver/dryer (which I will replace with a new one once I’ve proven it physically fits) and then the condenser and fan, which are pretty straight forward.
So, today I’m happy again.
Pond
Spaldingski, Lincs
You are obviously a very competent engineer/ mechanic, as you are making that job look very easy; when it really isn't for the vast majority.
As you have mentioned Stamford, I presume you live fairly local to me (Spalding), so I will be calling on you to help with my next project. ;):)
MickyG
Hi Pond
I would not say it has been easy, but equally it is not an impossible task with the right tools and a methodical, patient and determined approach.
It has been very time consuming, having to learn by trial and error the order in which work must be carried out, and with which tools.
Would I recommend it to anyone else?
- No, it’s a lot of work, and as has been said, it might be easier to look for a Z3 with it factory fitted.
(But looking for a suitable Z3 these days is not without a considerable investment in time: searching out cars to see, travelling around to look at over hyped, no poor quality cars, before hopefully finding a good one).
Would I be the prophet of doom and tell anyone not to do it ?
- Again , No.
It is not as difficult as some would have us believe: I have no specialist skills - other than being very practical and even more determined!
I am simply trying to break myths with facts.
It can be done by any competent person with mechanical aptitude and a good set of tools.
I would say the Z3 is a very special case, due to its wiring loom and electrical analogue simplicity. All Z3s were built with one common loom which included the wiring for all electrical options, whether ordered or not. It was also a time of stand alone analogue circuitry: none of the modern day inter linked CAN computer controlled systems seen in more modern cars. This removes the electrical complexity from the project making retrofitting Aircon a mechanical installation only.
Had the loom not been there I would not have embarked on this project as I have little confidence in that area. For others with electrical aptitude, they of course may take a different view and still take it on.
Would I do it again?
In a Z3, yes.
Would I do it for someone else?
No, thank you.
Do I hope someone sees what I have done and has the confidence to take on the project themselves - yes definitely.
(BTW Pond : You are quite right - we live very close by!).
Pond
Spaldingski, Lincs
That is not exactly true. There were at least two (possibly more) changes to the DME and other modules over the build period, as I have learned to my cost.
From 2000-on there was 'canbus' added to provide 'modern' electronics to quite a few wiring functions.
But it does seem that all of the 'normal' electrical stuff is common to all and the general looms are generic.
