Bognor Lean-to Project
Keep the Z3 you would be back at step 1 if you went for a Z4 we all know what your like.
Trouble is now if you want to repair you will need to remove some powder coat, apply heat to the base of the arm and give it a good twist.
Get yourself a bottle of acetylene :)
The damage was likely caused by a side impact, very unlikely to be caused by being dropped.
I agree with Lee, if it could be bent just by being dropped it wouldn't last very long on a car. Which means it must've been bent before it was powder coated and sent to you Malc. Have you approached the seller in the US about it?
  • Agree
Reactions: Lee
Mazza
Bognor Regis
Z3 1.9 M44 Roadster Z3 2.8 Roadster
Cant find a contact email address but must have one somewhere !!!!!
Mazza
Bognor Regis
Found the supplier and replied via ebay.
with pictures
See if they bother to reply now.
Found a replacement for £220 …. But not seen any pictures of it yet so will hold off at the moment.
Mazza
Bognor Regis
Dont know why …. But sprayed the doors and rear wing today where they had been primed.
It will be the smartest car in the breakers 😂😂😂
There is no end to your talents just can't keep your hands still
Mazza
Bognor Regis
Thought I may as well put the good one back on today
used a breaker bar and two lugnuts to stop it turning when I torqued up the drive shaft.
could have put the brakes back but no point rushing now …..
Got some enquiries out for an offside trailing arm so just have to wait ☹
PhilH67
Derbyshire
Hi Malc, did you get sorted for the trailing arm? Just seen this and thought they may have one you could use?
  • Like
Reactions: Lee
Mazza
Bognor Regis
Not on facebook so dont know how to contact them :arghh:
But I would take it !!
PhilH67
Derbyshire
would that be what you need?
I’ve asked the seller if it’s still available, contact is through FB messenger, if available I’ll get his contact details and pass them on
Matt Barnes
Portchester, Fareham
1998 BMW Z3 Individual 1.9 M44 B19
I've just joined the same group...some decent zeds being broken ..
Mazza
Bognor Regis
Thanks guys
