- Joined
- Jul 18, 2020
- Points
- 134
- Location
- Portchester, Fareham
- Model of Z
- 1998 BMW Z3 Individual 1.9 M44 B19
Morning!..I have the classic Crank No Start issues after restoring my 1.9 (off the road for 3 years). Car runs fine for 3 seconds in limp mode (ICV and TPS unplugged). My routing around is pointing to the EWS 3D Immobiliser. Mine has the thick Green/Black on Pin 1 and thick Yellow/Black on Pin2. My Green Pin10 sits at 13v output with the key in and drops to around 7v at Position 1. Ties in with my scanner reporting Terminal 30 Ok at key in and Terminal 30 Not Ok at Positions 1 and 2. If I pull Fuse 45 I get Terminal 30 Ok in all positions but obviously now the Immobiliser is in the Disabled state. I get Released status when plugged in, so EWS is reading the key ok. I have pulled the Instrument cluster to rule that out and at rest with the key out, I get only 20mA draw from the battery. Would anyone have a circuit diagram for this model of EWS 3D?... many thanks!
