  • Devon Z
    Devon Z replied to the thread Adding Cruise Control.
    Done mine many years ago, M52 TU with cable throttle but has ASC so has electronic throttle control. Didn’t need a clutch switch it was...
  • motco
    motco replied to the thread Adding Cruise Control.
    I'm certain that I didn't fit a clutch switch to my manual 2.2i M54 Reg. June 2002. It works perfectly.
  • Eureka
    Eureka replied to the thread ABS issues.
    Had my ABS repaid by https://www.ecutesting.com/categories/abs-pump-modules/ £250 lifetime warranty.
  • Kate and rod
    Day 4 part 2 Arisaig Evening meal at the old library Arisaig. WOW! locally caught mussels starter The seafood broil Needed all...
  • Grumps
    So yesterday we became very poor by visiting the extremely rich in Monaco! It opens your eyes i can tell you. I think we all have a...
  • jfinley
    UPDATE: Finally motivated to dig back into the car electrical issues and discovered this in the image. Thanks for the suggestions of...
  • IainP
    IainP replied to the thread Hand brake rattling.
    It’s actually not that difficult. Tools required, socket set and Allen/Hex bits. Loosen the wheel bolts. Jack the car and place an axle...
  • NZ00Z3
    NZ00Z3 replied to the thread Hardtop wind noise.
    Have you tried to adjust the door latch, to get it to close in a bit more?
  • NZ00Z3
    NZ00Z3 replied to the thread ABS issues.
    Hi Richard The fault codes you provided are in Hexadecimal (base 16). You didn't give any descriptions for what they mean. So, I went...
  • IainP
    IainP replied to the thread Wanted Exhaust Vibration Damper.
    Simple fix is buy a D exhaust clamp of the correct diameter for your exhaust pipe from eBay/Halfords/auto shop. A set of m8 rod...
    Smudgemanuk replied to the thread Happy birthday Smudgemanuk.
    It was indeed! I kept it sensible and had a lovely Japanese dinner out with family.
    Thank you, Shelly! You are very good at doing this for people, a lovely service to the forum.
    Thank you very much everybody!! Much appreciated! As part of a present there may be a future Nurburgring trip, so that is definitely...
  • Stevo7682
    Stevo7682 replied to the thread Adding Cruise Control.
    You need the clutch switch so cruise knows to disengage if pedal is pressed. Stephen.
  • Stevo7682
    If your car is a 3.0 manual 3 parts 1x cruise control stalk 1x clutch switch 1 x telematics module That is all you will need...
