  • Argyll Andy
    Always carry a box of these. Was sceptical when they were recommend in Halfords but they work fantastically. Also carry a spray bottle...
  • TiggR_R1
    MickyG, Please disregard post 161 completely. My mistake I got the relay positions confused when turning over the relay to check...
  • Matt Barnes
    well the weather has put paid to doing anything today.... hoofing it down earlier and blowing a hoolie.....cover got pulled off by the...
    Pond replied to the thread Codes help.
    If you clear the codes and they come straight back it means the faults are still there, so the issue is 'live'.
  • Devon Z
    Devon Z replied to the thread Codes help.
    That’s pretty much what I thought 😳😳😁😁 Wow thanks for the detailed response, you really need to try and sleep at night though 😁 As I...
    https://www.realoem.com/bmw/en/showparts?id=CN33-USA-06-2002-Z3-BMW-Z3_25i&diagId=33_0998 This shows up as a USA car in real oem are...
    Smudgemanuk replied to the thread Driveshaft Clunk??.
    AHH! I thought we might finally be getting somewhere!
    Did you match the part numbers when buying the part? Find the part you are looking to replace on RealOEM.com and then use that part...
  • K
    I went to change my LR wheel speed sensor and found the alignment fins in the connector is different than the OEM. 2002 2.5 Roadster.
  • Althulas
    Althulas replied to the thread Codes help.
    In the AI responses it did give a few hits on similar issues, give it a try at least a starting point of things to look at.
  • Althulas
    In the same ‘conversation’ I inputted your other two codes BMW Code 76 (Speed Sensor, Signal Interference) indicates that your ABS/ASC...
  • Althulas
    2. Wiring or Connector Issues Corroded pins at the ABS module block or a break in the CAN bus wiring harness can cause data loss. [1, 2...
  • Althulas
    I googled your codes and got… A BMW Z3 code 94 (ASC/DSC: CAN data fault from DME/DDE) means your traction control module (ABS/ASC) has...
  • Randall M
    Randall M replied to the thread 1998 Z3 1.9l Autocross Build.
    AI fun....
  • N
    Neil Wilson replied to the thread Rear dif mount bush..
    Picked my car up from local garage today having had the new AKG polyurethane bush fitted, mechanic said it was easy enough to fit, I...
