  • Fender2004
    Fender2004 replied to the thread Disc pads renewal..
    Do you not have to inform your insurance company that you have changed the discs to drilled and grooved?
  • Bluethunder
    Bluethunder replied to the thread Stereo doesn't switch off.
    Some better photos of the multi plug wiring.
  • TiggR_R1
    Hi MickeyG. I hope this helps.
    Thank you: that is what I expect it should do. Annoyingly mine does not! Could I ask a favour? I have spent literally the last 6 days...
  • Gatsoburner
    Gatsoburner replied to the thread New here.
    Mint..Great looking car, wife disagrees but she can stay home Welcome.
  • Bluethunder
    The red wire was connected to the aftermarket unit. I've tried to see what it was connected to inside the dash but it just came out...
    Pond replied to the thread New member.
    The later M52 (TU) engine has double vanos, same as the M54. People with much more knowledge than me will tell you the M54 is almost...
  • IainP
    IainP replied to the thread Z4 E85 audio wiring.
    Pretty much what Althulas said, I’m probably looking at doing the same and proper Iso connector will retain the steering wheel controls...
  • F
    Flintstone64 replied to the thread New member.
    The M is outside my budget. Certainly agree about bodywork, from my RS experience rust can be hidden in unexpected places. Apparently...
  • IainP
    IainP replied to the thread Stereo doesn't switch off.
    I suspect It’s that red wire with the blue connector. I had mine out yesterday and I don’t have that, just the multiplug, what does it...
  • Bluethunder
    Hi, I've removed the aftermarket stereo fitted to my car when I bought it and refitted the OEM unit. But when the key is removed from...
  • D
    drytz posted the thread New here in Introduce Yourself!.
    Hi all! I’ve had my Z3 Coupe 2.8 -99 for quite a while now which I’m starting to be reminded of. So here to learn, and make sure I can...
    2.8s are more common and the 3.0 litres do seem to command a premium. I have a 3 litre (M54). It's quite 'pokey' actually and a nice...
    Pond replied to the thread Disc pads renewal..
    OK. If you like. :thumbsup:
    I won't mention mine, then. :whistle: 🤭
