  • Rod and Kate
    Rod and Kate replied to the thread P.O.T.M MAY 2026.
    Can't upload picture. I do have a alert saying possible spam detected in zroadster.
  • hard top
    hard top replied to the thread Forum Images..
    No problems at this end, all the photos in this thread are visable. Here you go, one of my old photos from the media gallery :-...
  • GazHyde
    GazHyde replied to the thread Forum Images..
    In the short term while we get the image problem sorted I think a possible workaround is to upload the image to media gallery, then you...
  • Pingu
    Pingu replied to the thread Just for @ktnez99.
    As my old mum used to say, it's always better to be a bit flaky than to have a soggy bottom.
  • W
    I did think this but I did each track rod end at a time so to avoid putting wrong side on, can videos be uploaded to this forum? If so...
  • W
    Hmm. Good point I’ll check again morning it’s weird as it does it also now with the car being on the floor not on jacks but doesn’t do...
  • Lee
    After re reading your first post you might not having anything wrong. The strut and spring will move together, the top mount will stay...
  • Lee
    Other thing it could be is the track rods are on the wrong sides, they have a kink in a way that misses the wheel when on near full...
  • W
    Hi will try check tomorrow it’s just confusing as unless one done track inner or out rod wrong there shouldn’t be much if any movement...
  • Gatsoburner
    Whats these Under bonnet protection stickers ?..
  • L
    Llama replied to the thread Need help with smog.
    I assume you drove around on the freeway for at least an hour before your test, ensuring your cat was as hot as hell?
    https://www.realoem.com/bmw/en/showparts?id=CM12-EUR-12-1999-Z3-BMW-Z3_19&diagId=31_0209 Washer No 7 in the diagram, check its there if...
  • Lee
    Can you tell if its one side or both sides, hard to pin point from your explanation. Get your eyes on the mount on the top while someone...
  • Stevo7682
    Stevo7682 replied to the thread P.O.T.M MAY 2026.
    Hi everyone just post your pictures up as normal for now as others have said various ones not visible for me its 3,7,8,9 I know there...
  • W
    Hii Lee , so how would I acces that? So when I’m looking at the strut from under the car the strut along with spring seem to move Left...
