  • W
    Hi sorry to ask a stupid question but how did you get the back piece on when it’s already in the wishbone ? Gonna try attempt to make...
  • Pingu
    Pingu replied to the thread Spotted in Seville.
    We're planning the second part of our NFFC tour, so might see it there :thumbsup: .
  • Pingu
    Pingu replied to the thread '97 M44 Intake Path.
    I have no experience on your engine or "normal" 6-cyl engines, but modifying standard parts is much easier than making stuff from...
    Pond replied to the thread Classic Wheels Oakham.
    I didn't know about this one. Weather depending, this could work for me.
  • koolflyer
    Anyone taking their Z3 to Classic Wheels Oakham, Rutland Showground on Sunday 17th May? Pete KF
  • Scooblitz
    Scooblitz replied to the thread '97 M44 Intake Path.
    I don’t think the 6cylinder airbox will work on an M44 engine as the MAF, throttle body and intake hoses are totally different angles...
  • B
    bmwz3tower replied to the thread '97 M44 Intake Path.
    Will the M54 airbox fit the studs for the m44 airbox?
  • E
    EwanV posted the thread Newbie in Introduce Yourself!.
    Hello all, I’m a second time owner of a Z3. Had a 1998 Boston Green 1.9 in my early 20s for a couple of years. 15 years on, I now have...
    Cheers, 100%. im in the camp thats its good enough for now and ill play with it later. Red is a nightmare isnt it.
    colb replied to the thread Help wth warning lights?.
    BNW specific code reader needed plus a 20pin to 16pin cable changer to allow the scanner to be plugged into the round Pac-man socket in...
    Pond replied to the thread Rebody Mittaws 250 SWB Coupe Build.
    Hats off matey. Not something I would contemplate doing. I have noticed quite a few 'micro scratches' in my paintwork, under harsh LED...
  • G
    greisinb replied to the thread '97 M44 Intake Path.
    Are you/do you propose swapping out the entire airbox assembly (as opposed to just the intake tube) from a 6 cylinder model? Do you know...
  • Trevor /chedder
    Trevor /chedder replied to the thread Help wth warning lights?.
    I've had the abs box needing the two fixed connections needed resoldering, also had faulty sensors. The latest one was, I think, a dirty...
  • Althulas
    Althulas replied to the thread Time I pulled my finger out.
    Forgot to add for people who noted the earlier code reading showed a fault on injector 6. On testing and cleaning them with THIKPO...
  • Althulas
    It much of an update, not the professional job of soldering but everything works as it should. 3D printed cover from a company in...
