AleNod
Event
North Notts Classic Car Show Monday 4th May.
I sometimes get that because of my vpn (always on), try turning that off and see if that allows access ?
Wednesday at 10:48 AM
Event
I tried to book via the link and directly via the website but just kept getting the following message.
Wednesday at 10:44 AM
M
MickyG
How To Guide
How to remove z3 facelift inner roof liner
Has anyone retro fitted one into a pre-facelift? And how easy/difficult is it to make a good finish? I have a good lining in my donor...
Wednesday at 10:29 AM
Rebody
Roof and Windscreen issue
I would say that if the tub sits straight and the door shut lines up nice then it's correct and the error is at the windscreen surround...
Wednesday at 10:13 AM
D
Dave in Southampton
Rebody
Hi Dan My rear tub is also an issue, but the real issue is at the widscreen. The tub fits beautifully to the door shut. The screw holes...
Wednesday at 9:56 AM
T
tazmanic
air bag module
let me clear this up a bit. one person can buy an item and its great another not so as with cars we dont all like the same thing some...
Wednesday at 9:06 AM
Speed sensor in the diff. Z3
No oil loss i had to change the silver zeds one when i got it as when you were driving it speedo was pulsing and reading like 65 for...
Mar 31, 2026
Malcolm
2.8 Exhaust
Powerflow cat back,sounds good but to be honest I haven’t had the opportunity to give it a decent run yet,as the dealership is only 2...
Mar 31, 2026
ABS Pump replacement and brake bleeding
The later pump will definitely allow an abs bleed with correct spftware. The earlier pump less so as it does not communicate with a lot...
Mar 31, 2026
Zola3
If you have INPA, there is an option to bleed the ABS pump - I have done it before - you have to time it with the bleed nipple on the...
Mar 31, 2026
Rudyrov
Most pictures of the diff back cover I have seen show the sensor above the max level plug. If yours looks like this then YES, the sensor...
Mar 31, 2026
Delk
It's above the oil fill plug so nothing will come out.
Mar 31, 2026
2.8 Exhaust
What did you put on? I did a Magnaflow cat-back on my 3.0i a couple years ago. I love it with one minor gripe: it's got a resonance at...
Mar 31, 2026
Pond
I need to remove my diff-mounted speed sensor to check it isn't clogged with crap, as part of my investigations as to why my speedo is...
Mar 31, 2026
Searching for my Dads 1999 Z3 V410 ETC (Currently SORN)
LOL....I looked at the top picture and thought "Hmm...I don't see the driver's side door dent". Then scrolled down and saw it on the...
Mar 31, 2026
