  • C
    c.smith replied to the thread Thicker Sway Bars.
    In terms of connecting the end of the aftermarket anti roll bar, how would you go about doing it? Because the OEM system is a pin into...
  • Pingu
    Pingu replied to the thread Thicker Sway Bars.
    I've done it to two cars. One is my M roadster, which now has an M Coupe rear anti-roll bar - no great problems. The other was when I...
  • Lee
    Lee replied to the thread Thicker Sway Bars.
    Strongly recommend these for the Z3, they do lean alot I would fit those bars with normal rubber bushes so you do still have a bit of...
  • Hwk-I-St8
    Hwk-I-St8 replied to the thread Roof Tension Cables ?.
    I see that they have long side and short side cables. Would I need both? I know my tension cable(s?) broke as there's a spring hanging...
  • Hwk-I-St8
    Absolutely, I'll hook you up
  • C
    Will I need those for both front and back?
    Smudgemanuk replied to the thread Thicker Sway Bars.
    These things that secure the D bushes on the anti roll bar to the chassis
  • C
    I've actually recently replaced the front control arms along with drop links, but I will buy some rear replacements as well, what do you...
    I replaced the D bushes and drop links on mine recently, so I pretty much had the anti roll bar off. It is not that tricky to do but I...
  • C
    Does anyone have experience of fitting this uprated Sway bar kit? I have a 2000 Z3 Roadster 2.8 preface lift, and I'm looking for less...
  • Duncodin
    Duncodin replied to the thread JANUARY 2026 P.O.T.M.
    I often prop the phone up and record video of meself working or whatever and pick fhe best frame as a picture for sharing. Easy to do...
  • Duncodin
    Duncodin replied to the thread Rebody Z3 Tribute GT project.
    I like that. And your clock will be absolutely accurate twice a day which is better than it was. 🤞
  • Pls
    Pls replied to the thread Red Highland Z3 1.9 Roadster.
    Thank you! And you're absolutely right - i did a write up on the 2024 event, when there were nine other bright red soft top sports cars...
  • Synclare
    Synclare replied to the thread Red Highland Z3 1.9 Roadster.
    Always look forward to your postings from the Highlands. I recall a previous posting where you mentioned you went to a car show straight...
  • Foglem
    Foglem replied to the thread Rebody Z3 Tribute GT project.
    It is extremely cold here now, so I can only work on so much before freezing in place. Fun things are in the works though! I'm keeping...
