Mad2718
Event
Memorial cruise for t-tony 19-10-2025
Hi Grumps, sorry for the late notice but Mue and I are going to have to pull out of the run. So sorry for the hassle this will cause...
Tuesday at 8:43 PM
M
Mr.Hemi
New 2000-2.8 Z3
Thanks for the welcome. And thanks for suggestions. I did change rear end fluid and that did make a noticeable difference in cutting...
Tuesday at 8:30 PM
mikeyH
I'm going to be in trouble for saying this but it's moved so far away from the original concept and it is now IMO a 2 seat 4 seat car...
Tuesday at 8:29 PM
Grumps
Event
Likewise mate.
Tuesday at 8:19 PM
AntStark
Me neither ..it’s also called ‘ESP’ if you are after some . Anyway it arrived today from Opie ..looks and tastes like normal Dot4 to me 😀
Tuesday at 8:04 PM
I found my post here about it... https://zroadster.org/threads/steering-wheel.65569/post-838813
Tuesday at 7:43 PM
Bozzy
Event
Good evening all. Amy and I are doing the final preparations for Sunday. Dave (Grumps) has confirmed the groups but wanted to double...
Tuesday at 7:42 PM
I thought I had one, but all I have are pictures of the removal/install process. I'll get one and post it....
Tuesday at 7:41 PM
Pauliebhoy
Not that model but I bought a G29 2.0 for the wife and a X2 M35i for me both new.....in the same month ( the X2 was an impulse buy after...
Tuesday at 6:44 PM
Photo?
Tuesday at 6:41 PM
B21
I watched it last night…I thought it was pedestrian in its pace…I nearly fell asleep.. The consensus from several similar reviews is ...
Tuesday at 6:22 PM
Tuesday at 5:57 PM
Tuesday at 5:35 PM
Tuesday at 5:19 PM
Tuesday at 4:45 PM
