AntStark
Me neither ..it’s also called ‘ESP’ if you are after some . Anyway it arrived today from Opie ..looks and tastes like normal Dot4 to me 😀
Tuesday at 8:04 PM
I found my post here about it... https://zroadster.org/threads/steering-wheel.65569/post-838813
Tuesday at 7:43 PM
Bozzy
Event
Memorial cruise for t-tony 19-10-2025
Good evening all. Amy and I are doing the final preparations for Sunday. Dave (Grumps) has confirmed the groups but wanted to double...
Tuesday at 7:42 PM
I thought I had one, but all I have are pictures of the removal/install process. I'll get one and post it....
Tuesday at 7:41 PM
Pauliebhoy
Not that model but I bought a G29 2.0 for the wife and a X2 M35i for me both new.....in the same month ( the X2 was an impulse buy after...
Tuesday at 6:44 PM
Photo?
Tuesday at 6:41 PM
B21
I watched it last night…I thought it was pedestrian in its pace…I nearly fell asleep.. The consensus from several similar reviews is ...
Tuesday at 6:22 PM
Tuesday at 5:57 PM
Tuesday at 5:35 PM
Tuesday at 5:19 PM
Tuesday at 4:45 PM
I bought a BMW steering wheel on ebay that was the same as my OEM wheel. Then I sent it to Royal Steering Wheels for customization. I...
Tuesday at 4:43 PM
Hi there, I replaced mine with Walbro Motorsport 255LPH which works great. Mine is the s50 engine so I don’t know if it’s the same ...
Tuesday at 4:39 PM
Need Help Choosing the Correct Radiator for 2006 Z4
N52 Z4 autos have a unique radiator. Part number 17117551635. Manual gearbox cars use an E46 radiator that's used on all manual Z4's...
Tuesday at 4:34 PM
Alpine White 23i - #31
To much cleaning and faffing of late so time for a well overdue drive. The good thing about going out in the fog is that getting a...
Tuesday at 2:32 PM
Bottom
