I found my post here about it... https://zroadster.org/threads/steering-wheel.65569/post-838813
Oct 14, 2025
Bozzy
Event
Memorial cruise for t-tony 19-10-2025
Good evening all. Amy and I are doing the final preparations for Sunday. Dave (Grumps) has confirmed the groups but wanted to double...
Oct 14, 2025
I thought I had one, but all I have are pictures of the removal/install process. I'll get one and post it....
Oct 14, 2025
Pauliebhoy
Not that model but I bought a G29 2.0 for the wife and a X2 M35i for me both new.....in the same month ( the X2 was an impulse buy after...
Oct 14, 2025
Photo?
Oct 14, 2025
B21
I watched it last night…I thought it was pedestrian in its pace…I nearly fell asleep.. The consensus from several similar reviews is ...
Oct 14, 2025
Oct 14, 2025
Oct 14, 2025
Oct 14, 2025
Oct 14, 2025
I bought a BMW steering wheel on ebay that was the same as my OEM wheel. Then I sent it to Royal Steering Wheels for customization. I...
Oct 14, 2025
Hi there, I replaced mine with Walbro Motorsport 255LPH which works great. Mine is the s50 engine so I don’t know if it’s the same ...
Oct 14, 2025
Need Help Choosing the Correct Radiator for 2006 Z4
N52 Z4 autos have a unique radiator. Part number 17117551635. Manual gearbox cars use an E46 radiator that's used on all manual Z4's...
Oct 14, 2025
Alpine White 23i - #31
To much cleaning and faffing of late so time for a well overdue drive. The good thing about going out in the fog is that getting a...
Oct 14, 2025
Rudyrov
AI Overview View all DOT 4 brake fluid has higher dry and wet boiling points than DOT 3, making it better for...
Oct 14, 2025
