  • smiffy
    smiffy replied to the thread F1 Fantasy F1 2025 Season..
    listening to Lando on comms near the end, it sounded like he was on the verge of passing out. Poor ciruit/car combination and driver...
  • smiffy
    smiffy replied to the thread Z3 2.8 won’t rev 🤷‍♂️.
    looks like it's been a good weekend for dying 2.8's!
    colb replied to the thread Thanks for letting me join.
    @Scooblitz is correct in what he says, your pictures show corrosion on and at the ends of the cover sills, the actual covers not being...
    colb replied to the thread Newbie.
    Welcome to the Forum, all you will ever need to know can be found on here. As we are Worldwide its a good idea to update your User...
  • Rhyds
    Rhyds replied to the thread Z3 2.8 won’t rev 🤷‍♂️.
    Update After a lot of frustration with the mechanics… I met a man who can.. with electronics. 2 burnt out capacitors (or something) &...
  • Zaniei3
    Zaniei3 replied to the thread DMTL ground issue.
    I found a melted brake light socket in the right side and it looks like it shares the same ground connection as DMTL. G301 does anyone...
  • andyglym
    andyglym replied to the thread F1 Fantasy F1 2025 Season..
    Other than when Hamilton went on to soft tyres and stormed back up to Antoneli, then his brakes went, it was a procession.
  • mwpe
    mwpe replied to the thread Bicester scramble..
    Afew more. You don't often see 2 Z8s
  • AntStark
    AntStark replied to the thread Can anyone tell me what this is.
    This may help you https://www.realoem.com/bmw/enUS/select Not seen in that position before but that looks like a secondary air pump...
  • AntStark
    AntStark replied to the thread Newbie.
    Good plate 😎😉
  • mwpe
    mwpe posted the thread Bicester scramble. in General Banter.
    A few pictures from the Scramble today.
  • Amy H
    Evening all. The run leads have the route but, just in case any problems occur while out, here is the route. Any questions as Dave said...
  • NZ00Z3
    NZ00Z3 replied to the thread Cruise control problems.
    OK, lets get you set up with the INPA software. This means we both have the same set up and saves a lot of confusion. It can be down...
  • D
    Dukeisok replied to the thread Cruise control problems.
    I diy enough to get myself into trouble ;) I’m more than willing to launch into this. I’ve rebuilt several older cars and can run a...
  • NZ00Z3
    How much of a DIY person are you? I ask up front because you'll need to be able to: - Set up the INPA software on a windows laptop...
