Pingu
Shifting question
I actually think you are right, and @Lee did answer a different (but very common) question. Just confirm that your gearstick always...
Wednesday at 5:28 PM
bombur
Sundays job
Wednesday at 5:19 PM
motco
Incompetence everywhere..
I drew up this Law some years ago and the only changes have been for the worse. Motco's Law of Universal Incompetence: "Always assume...
Wednesday at 4:55 PM
ssscomp
Shifting question
Thanks for getting back to me. Are there any downsides of changing the gearbox fluid and can any motor "place" do it and if so what oil...
Wednesday at 4:44 PM
Lee
Near side rattle
It wouldn't give off a rattle noise as its in a rubber coated sheath.
Wednesday at 4:36 PM
N
Neil Wilson
Near side rattle
Does hand brake cable rattle on exhaust?
Wednesday at 4:33 PM
N
Neil Wilson
Near side rattle
Thanks, I’ll have a closer look. Attachment nuts/studs look pretty rusty, could you tighten yours?
Wednesday at 4:32 PM
Lee
Near side rattle
Gently pull the handbrake up when you next expect it to rattle, see if it goes away. Quite common rattle point on the rear of a Z3.
Wednesday at 4:30 PM
Lee
Shifting question
Nope a response to your issue, if it's an issue. These gearbox's suffer with a problem of sleeves wearing causing the gearchange to be...
Wednesday at 4:27 PM
ssscomp
M roadster exhaust tips
Actually I installed the Z3M Performance Axle Back Exhaust from ECS tuning and oh wow wow wow. Perfect sound, quicker, tailpipes look...
Wednesday at 4:21 PM
ssscomp
Shifting question
Thanks. I think your response was an answer to a different post.
Wednesday at 4:17 PM
ssscomp
Those little circular decals around the cabin temp adjustor
Z3 M Roadster & Coupé
So I have a 1998 BMW M roadster and it is great. There are three turning knobs on the control panel, the one on the left directs the...
Wednesday at 4:15 PM
Kenhayes247
An independent garage on the way into Devizes quoted me 120 pound to mount 4 tires, valves and balancing. There were no tires to remove...
Lee
Shifting question
Hello mate, what you're describing is the sticky 5th gear pin. With this gearbox you can have all those pins in the gearbox replaced for...
Wednesday at 4:10 PM
Lee
Holy cow man, that shock could have failed and sheered both those bolts off. I would be having a serious word with that garage. Plus...
Wednesday at 4:06 PM
Bottom
