  • S
    SEB 57 replied to the thread Présentation Z3.
    Bonjour, Je vous remercie et je vais utiliser une appli de traduction pour communiquer . Bonne journée
  • S
    New M toy, upgrade from a Triumph Speed Triple and a Z3 2.8 ...... same picture as my intro posts but now with the tonneau tucked in...
  • Matt Barnes
    the actual hubs came off really easily and on the offside I pulled it off with my hands... it's the inner race that's separated and...
  • Andybpowell
    Andybpowell replied to the thread Z3 EV Conversion.
    Yes it's getting there, cost an arm and a leg and then we walked into some expensive problems mainly the triple garage was full of...
  • Matt Barnes
    Morning all ..... I just hope I haven't been scammed, but I've been in touch with the seller and they confirmed it's the right sill for...
  • Z
    Zephyr replied to the thread Présentation Z3.
    Bonjour et bienvenue. Il sera difficile de communiquer en français, donc vous feriez mieux d'utiliser une application de traduction si...
  • Matt Barnes
    thanks Ken....I did think of something like that and will probably take your advice when I get back to it next weekend. I just got a bit...
  • Kenhayes247
    Matt - if you cut a vertical line down the entire length of the bearing shell as opposed to across. Use your dremel and a suitable...
  • S
    SEB 57 left a message on Mazza's profile.
    Bonjour Mazza, Je vous demande si vous avez des sangles de réservoir pour Z3 1.8l de 1997 Bonne journée
  • S
    Bonjour à tous, Je suis très heureux de faire parti de votre groupe. Je suis propriétaire depuis 1999 d'un Z3 1.8l, qui vient...
  • Marquisz3
    Realized I hadn’t posted updated photos of the engine bay yet, drop off the driveshaft to get corrected tomorrow, measure once cut 4...
    colb replied to the thread FIXD OBD Scanner.
    Its rubbish, stick with the Creator 310+ or upgrade to the 410 model.
  • S
    SaveMyZ3 replied to the thread Engine overheating.
    I removed the thermostat til I get this sorted. It is a new radiator and water pump. I checked radiator before fitting with hosepipe and...
  • IanA
    I've used my Creator scanner successfully on my two rebodies but Instagram has just popped up an extended advert for the FIXD scanner...
  • S
    SV8Predator replied to the thread ZZZ.
    You've posted in the wrong section of the forum. This is where you need to be...
