Rebody Replica veglia speedo gauge. A couple of questions..
Pond
Spaldingski, Lincs
3 litre Z3 pretending to be Italian exotica. Two previous E89 Z4s.
I have a question for anyone who has fitted the ETB replica Veglia gauges to their car.
Did you run new wires from the speed sensor on the diff to the speedo speed signal input?
Or did you use the existing BMW wires either from the diff output (red/brown and brown/black earth), or the BMW cluster output (black/white) on connector X271?
I ask because I have a problem with my speedo. I used the black/white wire from the output speed signal on the BMW cluster PCB which worked fine until last week. Now the speedo has gone AWOL. I have re-wired the signal cable to the red/brown BMW input cable from the diff and earthed the other diff wire. This has made little difference; my speedo goes nuts every time the car moves!
The manufacturer is adamant it can't be a fault with the speedo; it must be my wiring is picking up 'noise' and causing the speedo to go nuts. I am not convinced but need to eliminate this before I send the unit back for diagnosis.
BTW I originally wired into input 3 (red and blue) on the speedo, not the yellow input 2. I have kept it on the red/blue with the new wire as this is correct for the type of signal. I think I should have originally wired into the yellow on the speedo (input 2) with the original wire, but it all worked absolutely fine.
Thanks.
Pingu
Pond
Spaldingski, Lincs
This is my wiring diagram for the Speedometer. I've used BMW's symbols and wiring colour rules, but page numbers agree with my wiring diagram, not those of standard Z3s.
Ignore the circuit inside the big box - it is wrong, but the connection numbers and wiring colours are correct.
I have your wiring diagrams from before, thanks.
It is not so much "how" it is wired (as I know mine is correct), it's more about where the cables run and if they are the original BMW, or if they have been replaced, ideally with shielded cable.
As I said above, I am being told I have "noise" interfering with my speed signal from other cables within the loom.
However, I can't see where this "noise" has suddenly come from, as the speedo worked absolutely fine for months. My wires are the original red/brown and black/brown from the speed sensor directly to the speedo on input 2 (red/blue). I have earthed the black/brown directly to the car on a separate post so as not to get any interference from anywhere through the earth cable.
I have removed the speed sensor connector on the diff and cleaned it (although it looked fine). I have tested both cables running from the sensor into the car. Both have good continuity, so I know my cables are fine.
It still goes nuts whenever the car moves. I am 95% sure there is a problem with the speedo itself, but am being told it is almost impossible and must be my wiring.
Pingu
You could buy a cheap oscilloscope. Mine cost less that £20, and it's quite good.
Connect both wires from the diff to the 'scope. You should get a clean square wave. Noise would be "flutter" on the square wave.
Then reconnect the earth to the original position, and test again with the diff +ve wire and a wire from the 'scope to the same earth you are using for the speedo. Just a thought - have you checked the earth for the speedo?
Pond
Spaldingski, Lincs
Everything else works as it should. The earth to the speedo is common to all the gauges and all work fine. The speedo warning lights work, the odometer lights up, the backlight all works. The speedo powers up fine, just doesn't like the speed signal coming in for whatever reason (I am still convinced it is the instrument at fault not my wiring). Unless the speed sensor in the diff is playing up, which is highly unlikely, as it was all OK before the car was stored for the winter.
My hunch (and it is a guess) is that moisture has got into the gubbins of the speedo and is causing a fault. The ONLY thing that has changed by being in my garage for two months is condensation. All the external wiring connections are good with no issues.
Pingu
I agree and think it is your speedo that is playing up, but...
The earth wire is doubling up as a voltage wire for all the lights you talked about, and as a signal wire for the speedo. Signal wires are notorious for noise, but if it worked before, it should work now.
Does the speedo jump about when the wheels aren't moving, or only when they do?
A test I've done in the past is to disconnect the driveshafts and "drive the car". I was able to test the speedo and the diff sensor properly...
Pond
Spaldingski, Lincs
It did initially when I earthed the sensor to a shared earth (with the fuel sensor). I then removed that and earthed it directly onto an unused earth post. That stopped it from jumping about just by switching the ignition on.
Now it behaves OK when I drive up to around 20mph, then it just goes nuts. It registered 535mph on the odometer computer and I was in my cul-de-sac!
It's worth mentioning that this all started when the speed sensor wire into the speedo was wired from the speed output from the BMW cluster.
I have since changed the wiring (to try and resolve the issue) to the input from the speed sensor and earthed it separately. Before it was only erthed through the existing earth via the BMW cluster.
Whatever I do, it makes no difference in reality. Which is why the manufacturer believes it is external 'noise' causing the issue. I just don't see it, as whatever 'noise' is around, it was there from when I first wired the car and it worked fine for months.
Pingu
Daft question, but did you change the port on the speedo head when you changed the speed signal source?
It's Pin 2 for ECU input, and Pin 3 for diff input.
Pingu
Something else you could consider is resetting the pulse counter.
I would accurately measure several tyre revolutions to find the tyre circumference.
Assuming revolution is measured in metres...
According to Google (which is never wrong :whistle:), there are 9 pulses per tyre revolution, so Distance per pulse = Circumference / 9
Pulse Count per mile = 1608 / ( Distance per pulse )
Pond
Spaldingski, Lincs
My pulses were set accurately before at 9 pulses x rear tyre circumference rotations in one mile. It is approximately 7500 pulses per mile with my wheels and tyres. I have cross-referenced this and know it's pretty accurate.
I have now changed the pulses (just in case there was a glitch) to just under 7000 for now to see if it makes a difference. If it works (which I doubt), then I shall change the pulses back to very near where it was.
Pond
Spaldingski, Lincs
Anyway, details aside, did you (@Pingu) run new wires from your speed sensor, or did you re-use the ones in the BMW loom (red/brown and black/brown)?
That is the important info I need.
Pingu
BMW (BR/RT) wire to a block, and the speedo head wire (RT/BL) from the block to the speedo head (Pin 3)
BMW (BR/SW) wire to an earth point. I think it is the one near the RH door.
Pond
Spaldingski, Lincs
OK thanks. That is EXACTLY how I have it wired, yet I am still having problems with the needle going nuts.
The manufacturer is convinced it is 'noise' coming from elsewhere affecting the BMW signal wire (brown/red). I just don't see how, or why.
I am now leaning toward a fault inside the speedo causing it's own 'noise'.
I shall give it one more try on the road, then the speedo is coming out (again) and being sent back for diagnosis. Removing the dash enough to get the speedo out is a complete PITA, so I don't want to do that more than I absolutely have to.
Pond
Spaldingski, Lincs
I sent my speedo back to the manufacturer to test it. It is absolutely fine with no issues, so the 'noise' it is picking up must be coming from somewhere in the car's wiring. Just got to find where and why. Oh goody!
Pond
Spaldingski, Lincs
Speedometer was delivered back from ETB today, so now I have the task of trying to find where this mystery 'noise' or 'interference' is coming from.
I'll be honest and admit I have not got a clue what to look for, or what I am doing with this.
Especially as I still can't work out what could have changed so drastically in just two months of the car sitting in the garage.
But I need to sort it, as I can't bear anything not working 100%. It completely detracts from my love of the car and all my hard work and money at the moment.
ChrisD
Vale of Evesham
M44
A common and sometimes tricky to diagnose issue is with ground loops or ground rise. This can have the effect of mistriggering frequency inputs.
To be sure this isn’t your issue, you could run completely separate new wires directly from the power source (e.g. the battery) and also directly feed in the input signal with new wiring. Once you’ve established that the device can work in this manner then a process of elimination should pinpoint where the problem lies. Good luck with the diagnosis.
The oscilloscope is the tool that’ll help most but you may need help from someone with a working system for an A-B comparison.
Pond
Spaldingski, Lincs
Thanks for that.
The chap at ETB has been very helpful (I have been pestering him a lot by phone) but obviously doesn't know my car, or how it has been wired.
He has suggested an earth issue somewhere, or run a new signal cable from the sensor in shielded cable.
However, what I cannot fathom is why my speedo behaves the way it does. When I first drive it there is nothing registering on the speedo at all. After a mile or so the speed starts to register, but it is completely random and the needle goes nuts. It will register 180mph (the maximum) one second and 50 the next. This continues completely randomly until you come to a stop. The needle will continue to 'flicker' all over the place even at walking speed, then slowly calms downs and comes to rest at zero when stationary.
Surely, if it was 'noise', it would be there from when I set off? It is like once something starts to 'warm up' the problems start. But at 'cold' there is nothing.
I have a plan of things to disconnect/ isolate one by one. First is the radio aerial, as it doesn't supply a good signal anyway, so I won't miss that.
Then I will disconnect the diff speed sensor and see if I get anything registering on the speedo (I shouldn't).
I have a hunch it may be something to do with the earths from the warning lights within the speedo (handbrake, alternator and low OP). These all work as they should and extinguish on start but who knows??
Pingu
I would definitely run two wires from the diff sensor to a point as close to the speedo head as possible. The BR/SW wire from the diff should be connected to the same earth point as the power earth (SW wire from Pin 5 on the speedo head).
Unfortunately the "Veglia" speedo uses a common earth for speed signal and power earth return, so you can't eliminate signal earth as the problem.
By running the wires, you are eliminating any problems with the installed wires.
Disconnecting your drive shafts, and tying them up away from the diff output coupling, will allow you to "drive" the car without moving it. Don't go above 30mph on the speedo or you may get an ABS fault, but it will reset with an ignition reset.
Pond
Spaldingski, Lincs
I have noticed that I wired the speed signal incorrectly originally. I took the black/white speed output from the cluster and spliced that into input 2 (red/blue) on the speedo. I should have used input 1 (yellow) on the speedo. It worked, but I may have 'damaged' input 2.
So I am going to firstly wire everything back as it was (as I've chopped it around so much trying to get it to work) originally and try 2 things:
One is to splice the red/brown sensor input wire into the red/blue speedo input 2 with the sensor earth going through the cluster on the black/brown.
Second is to splice the black/white sensor output wire into the yellow input 1 with the earth going through the cluster.
I have a few other ideas if neither of the above work.
