LED Low Beam Bulbs
Gregor
I have a 2000 Z3 and would like to know if anyone has put LED Low Beam Bulbs in their 2000 Z3. or something better than the Original type bulbs. Tired of the Manufactures Bulbs
Thanks
LED bulbs should fail the MOT. Best option are Osram Night breaker replacements.
I used them in my Z3 and my E85 Z4 which have very poor headlights as standard.
Gregor
Thank you Tony for the advice. I will look into the Osram Night Breaker. Take care
Gregg
Hi @Gregor i am an active mot tester and can confirm what Tony is saying is correct Led dip bulbs in your age of vehicle would be a mot fail ( main reason is most of these bulbs produce a poor beam image and poor light projection.
As Tony has also recommended Osram nightbreaker range are good quality products and will improve the lighting on your zed over stock bulbs or most of the Phillips vision range would also be a suitable option.
Dont be tempted to fit higher wattage output bulbs as especially if you have a face-lift zed you will damage the headlight internals with the extra heat produced.
Stephen.
Gregor
Sorry for additional reply but I have been looking at the OSRAM Night Breaker and wanted to know if these are for European Z3 models as it appears the connection not with the L connector or do these just slide into the L connector. If this is the case the vehicle Finder did not work so are you suggesting the Night Breaker 200 and ECE Category H11? FYI, I am in the USA and not sure I can purchase this item. Thanks Tony
Gregg Levine
Hi Gregg, it's been about 8 years since I had my Z3 so I'm struggling to recall exactly what the bulbs looked like. However I do have a headlight unit for a Z3 in my shed so I will take a look tomorrow for you.
pa. Sorry, I didn't realise you were in the USA.
Gregor
Tony, Thanks again for getting back to me. I think I will see what the local Auto Parts stores have to say. I was not sure with this forum if I would have someone in the USA respond. Take care
Gregg
OK Gregg, I've been busy today so if you need me to check please let me know.
