For Sale BREAKING; 1997 Z3 1.9 M44, 57k only
Andyboy
SHEFFIELD
Atlanta blue, not that it matters much as every panel bar the bootlid and rear bumper was damaged.
No mirrors apart from a broken passenger one.
Very good original black hood, black leather with good seatbelt guides, lovely engine and gearbox + diff, door pulls good, excellent trailing arms and driveshafts etc etc.
It was a very nice example before it was pranged so very nice parts.
SOLD: steering rack, exhaust.
Andyboy
SHEFFIELD
So, a full list:
ABS pump, the old type with the ECU behind the glovebox £35.
ABS ECU - as above £20.
Aerial module - it looks as new £80. SOLD
Badges for the bootlid and bonnet vents - I have two £10 each. Some small marks but pretty good. SOLD
Body control module behind the glovebox £30.
Atlanta blue rear bumper in very, very nice condition. Replace your tatty one for £50.
Diff - zero backlash and super clean 3.45 ratio. Fits 1.8 1.9 2.0 and 2.2 £200.
Door check straps £20.
Drivers door lock with solenoid £30.
Door pulls £100 each. SOLD
Door striker £15.
Driveshafts - 1.9 narrow body only and as tight as a drum £35 a side.
Engine - clean and a very nice runner £500.
Fuel pump £70.
Front undertray £25.
Front hubs with ABS sensors, wheel bearings etc - fit all Z3's. The 18mm bolts all came out. £50 a side.
Front struts - standard 1.9. mildly rusty but low mileage and not leaking - £50 the pair with springs.
Gearbox £120. Fits1.8 1.9 2.0 and 2.2
Gearlever boot, black kappa leather £20.
Glovebox lock £20.
Grilles, very good condition £25 each or £40 for both. SOLD
Heater valve £20
Hood - original BMW with a very good rear window. £150.
MAF - proper Bosch. £40
Mirrors are broken - 20 quid each for parts.
PAS oil cooler loop - nice condition and I've cleaned up the few rust spots and painted it £60.
PAS pressure hose from the pump to the rack in exceptional condition. 1.8 and 1.9 only £80.
Propshaft £40.
Steering rack sold.
Seats - black leather in very good condition. Working motors, no front-back play and unbroken belt guides £150.
Door cards to match above, £60 without the handles.
Speedo £50.
Steering wheel - 3 spoke standard type, fits early cars until mind/late 1998 £60. SOLD
Switch blanks (narrow type) £whatever
Trailing arms - superbly rot free. The drivers side had a bad wheel bearing so I removed the hub flange £150 a side. Good backplates.
Wheels. Yeah, the usual Starfish things, one or two good tyres and some kerbing. £60 or I'll remove the tyres and weigh them in.
Window motor, passenger only £25
X brace - again, really nice and rust free. £80.
Others: tail lights, passenger side repeater, window switches, calipers, passenger door seal, boot seal.
No window regulators, good mirrors or panels.
Rod and Kate
York
2.8 Z3
Do I take it that the under tray, will fit any pre-face lift Z3. Ours is a 2.8.
Thanks.
Andyboy
SHEFFIELD
£100 plus postage so £115.
All four work fine with bleed screws that undo, no seized pistons or damaged dust boots.
