So seeing as a fair bit of the Z3 was based on the E36 and E30 I thought to myself: what better place to ask this question than on here.
Video LINK:
View: https://youtu.be/F6RgNVt5fZo
I've got a BMW E36 and its been in the family for a very very long time. Unfortunately for the past few years it's had intermittent overheating problems.
The problem started about 3 years ago when one of the coolant hoses came apart during a long journey and caused the anti freeze to splash out in the engine bay which caused some overheating. We pulled over immediately as soon as the engine had started to overheat and we secured the hose on with a rope - just as a temporary solutions for a few hours until we could source a replacement hose. We changed the hose and all was good for a year or so. The engine has since overheated intermittently and there seems to be a severe loss of coolant but I'm not sure where it all goes? There is a very very small leak from the bottom of the expansion tank but it's insignificant and wouldn't cause the engine to overheat as often as it does.
Today we were supposed to go to Birmingham, only about 40 miles away, about 5 miles in the trip the engine overheated with no apparent reason for it to be overheating, after adding water to the expansion tank (we no longer use antifreeze as it simply would not last with the amount we'd have to continually add to the tank) we set off again and had the same problem after another 4 or 5 miles. We stopped and repeated the procedure of adding more water into the expansion tank. The water doesn't seem to be flowing as it should though, it seems like it's getting blocked somewhere and cannot flow. Thermostat has been removed to see if this would remedy the problem but it hasn't. In the end we had to return home as it wasn't safe for us to take the car on the journey. On the return trip it took as an hour to cover 10 miles simply because of how many times we had to stop to let the engine cool down. Luckily the head gasket has not been damaged and the engine itself is still intact.
Any thoughts on what the issue could be?
Watch this video to see what the car does
Video LINK:
