Yellow warning: Fuel trim banks & Misfire, cylinder 5 6 4
jbrodin
Epsom, Surrey
Z3 2.2 SE
Hi
I get a yellow warning light every now and then. There are quite a few messages in the reader. I suspect they are all related since they all started to show at the same time shortly after being at a garage to replace the ABS module. Hopefully one of you have experience of this and can advise how to sort it out.
CB Fuel trim bank 2 control limit
F2 Misfire, cylinder 5
F3 Misfire, cylinder 6
F1 Misfire, cylinder 4
E4 Fuel trim bank 2, permissible range exceeded
BF Insufficient heat output, oxygen sensor behind catalytic converter, bank 2
E3 Fuel trim bank 1, permissible range exceeded
Thanks,
Jonas
